How to read the codes?
150,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
GEL
How do i read the codes?
Sep 9, 2023 at 12:27 PM
  • 110,248 POSTS
To check for codes on this vehicle, it is done using the ignition key and cycling the ignition from off to on a few times.
Here is a link that explains the procedure as well as provides definitions for the codes you may get:
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
Try this and let me know if it helps. Also, let me know the codes that you find and I'll help you through diagnostics or repairs.
joe
Sep 9, 2023 at 3:52 PM
