Check charging system warning light turns on
118,000 MILES • 6 CYL • 2WD • AUTOMATIC
PRODIGAL.S.81
  • 13 POSTS
I've replaced alternator and battery. Had charge system checked all voltage readings are good. Check charge system comes on about fifteen seconds after I start car. I've checked all connections and wiring. Can't figure out why I still get warning light. Any ideas?
Apr 1, 2019 at 7:01 AM
Good evening,
What is the voltage at the battery with the engine running?
It is possible you have a bad alternator.
Apr 1, 2019 at 9:38 AM
PRODIGAL.S.81
  • 13 POSTS
With load voltage was 14.24 without load 14.40. I put one alternator on it had a bad diode put two on burned up. It had soot on vents. This is the third in one year. No extras in car all factory.
Apr 1, 2019 at 10:24 AM
PRODIGAL.S.81
  • 13 POSTS
Could the PCM be acting up or does the starter have anything to do with it? Cranking had 11.67 volts and took 1.45s to start which is normal.
Apr 1, 2019 at 10:25 AM
Looks good.
What brand of alternators are you using?
Apr 1, 2019 at 10:36 AM
PRODIGAL.S.81
  • 13 POSTS
I believe it is a Duralast rebuilt. From AutoZone has stickers on it but all I found was do and part number.
Apr 1, 2019 at 9:47 PM
PRODIGAL.S.81
  • 13 POSTS
All I found was D L and part number.
Apr 1, 2019 at 9:48 PM
Okay, I attached a wiring diagram for you to view. Check the fuse listed for power on both sides.
Also, there is a DIM or dash integration module which controls the alternator load.
Do you have a scan tool to monitor the activity of this module?
Apr 1, 2019 at 11:00 PM
PRODIGAL.S.81
  • 13 POSTS
Yes, thank you. I'll check.
Apr 2, 2019 at 1:20 AM
You are welcome.
Always glad to help.
Apr 2, 2019 at 1:22 AM
