First some more information on the vehicle - air assist suspension for rear.
I would like to have the chassis independently operable from the body as I will be using the chassis without the factory body.
I have removed the air suspension switch from the jack compartment which turns the air suspension off, I will be mounting it in the project.
I have removed the wiring harness from the engine compartment so I can use that with the engine associated connectors, including the electronic engine control module recessed into the firewall. I have the power distribution fuse box with that wiring harness.
I have read that there is an air suspension control module in the dash someplace that I need to remove for the air suspension:
- Question: If I need that, where is that located?
I was told that I might need the GEM module, which I was told was part of the fuse box inside (on the right side of the dash by the driver's door - that fuse box):
- Question: Do I need that?
Another question: Is there anything else that I need to take from the body to allow full independent control the chassis free of the body?
Jan 12, 2018 at 5:38 AM
