Charging the battery
142,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
RANDALL729
  • 59 POSTS
I have a battery that is only a few months old. It's going dead frequently. I noticed the negative clip of the charger gets hot and the positive clip stays cold during charging. The charger is on 10 amps. Why could this be and should I suspect a defective battery? Thank you if there may an answer. Randall
Aug 3, 2019 at 8:14 AM
Good afternoon,
Charge the battery at a lower rate. Use a trickle charger and let it charge for several hours.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
The battery will be fully charged when the voltage is 12.6 volts.
https://www.2carpros.com/articles/car-battery-dead-overnight
Aug 3, 2019 at 8:21 AM
RANDALL729
  • 59 POSTS
So I should not be concerned of the negative battery charger wire getting hot? This is during charging. The charger is at 10 amps but goes down to 2 amps automatically as the battery gets charged.
Aug 3, 2019 at 11:40 AM
That is. The charge going into the battery.
Aug 3, 2019 at 2:45 PM
