The charging system worked until I cleaned the bulkhead wires?
67,000 MILES • 5.2L • V8 • AUTOMATIC
CHARLES
The reason for cleaning somethings works inside and others don't. I assume the mentioned bulkhead is the plastic block that connects to the firewall that wires pass through to the inside. I changed alternator and the voltage regulator, I believe they were OEM pretty rusty, but worked just fine.
Thanks, Charlie
Jul 17, 2022 at 5:35 AM
  • 55,628 POSTS
It has to be a connection problem, I would recheck all grounds and power leads, also the voltage regulator needs to be tight and grounded well. Here is a guide that can help you test the system:
Jul 18, 2022 at 2:10 AM
CHARLES
All connections seem good. Could it be the ballast. Horn relay?
Jul 18, 2022 at 11:23 PM
  • 55,628 POSTS
You could have defective replacement parts; I would have them checked. We don't have any wiring diagrams for this car in AllData or Mitchell 1.
Jul 19, 2022 at 4:24 AM
CHARLES
I think I got it. Two wires switched. Just when you think you're a genius you look like a dummy. LOL
Jul 19, 2022 at 4:26 AM
  • 55,628 POSTS
Np I have done the same thing :) Use 2CarPros anytime, we are here to help. Please tell a friend.
Jul 20, 2022 at 5:07 AM
