Charging system service required popped up on my dash
72,079,058 MILES • 2.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
RYAN HOLOWATHY
I want to know if it’s the alternator or battery the problem. Starts no problem light do not dim while under load, but I left it idling for about half hour maybe less and when I came out side it was dead I needed to boost it back.
Apr 11, 2020 at 1:55 PM
  • 110,246 POSTS
If it was running, stalled, and needed jump started, the first thing we need to do is check alternator output. It is really easy to do. All you need is either a volt meter or multi meter.
Here is a link that shows how it is done. Try this and let me know the results.
Here are a couple links to help with testing:
______________________________________
If you determine the alternator is bad, here is a link that shows in general how one is replaced:
https://www.2carpros.com/articles/how-to-replace-an-alternator
___________________________________________________
Here are the directions specific to your vehicle:
2014 Mitsubishi Lancer FWD L4-2.0L (4B11)
Removal and Replacement
Vehicle Starting and Charging Charging System Alternator Service and Repair Removal and Replacement
REMOVAL AND REPLACEMENT
REMOVAL AND INSTALLATION [2.0L ENGINE NON-TURBO, 2.4L ENGINE]
pic 1
pic 2
pic 3
REMOVAL SERVICE POINTS
[[A]] A/C COMPRESSOR AND CLUTCH ASSEMBLY REMOVAL
1. With the hose installed, remove the A/C compressor and clutch assembly from the bracket.
2. Tie the removed A/C compressor and clutch assembly with a string at a position where it will not interfere with the removal and installation of the generator assembly.
[[B]] GENERATOR ASSEMBLY REMOVAL
Remove the generator assembly to the downside.
INSTALLATION SERVICE POINTS
]]A[[ GROUNDING CABLE INSTALLATION
pic 4
1. Install the grounding cable within the area marked with A in the illustration.
2. Tighten the generator assembly mounting bolt to the specified torque.
Tightening torque: 44 ± 10 Nm (33 ± 7 ft-lb)
]]B[[ A/C COMPRESSOR AND CLUTCH ASSEMBLY INSTALLATION
pic 5
Tighten A/C compressor and clutch assembly mounting bolts to the specified torque in the order of number shown in the illustration.
Tightening torque: 23 ± 6 Nm (17 ± 4 ft-lb)
Apr 11, 2020 at 2:58 PM
