Charging system issue it starts charging then stops?
202,469 MILES • 4.0L • AUTOMATIC
SMITH29388
  • 5 POSTS
Truck died and battery was dead, tested it and. Changed battery and advanced auto said alternator was bad. So I replaced that. It runs for about ten minutes the fan slows down and it over heats. Also testing the alternator again, it starts charging then stops.
Jun 20, 2026 at 9:02 AM
  • 55,721 POSTS
Hello, It sounds like you got a defective alternator, when it says it is not charging lets do this test.
https://www.youtube.com/watch?v=Z-p4dMJUpUw
Please start a new thread for the overheating issue.
we only handle one problem per thread, please post your new question here, you must be logged in.
Please go over this guide and get back to me.
Jun 20, 2026 at 9:55 AM
SMITH29388
  • 5 POSTS
I put a new alternator and battery and new serpentine belt on it. It will run for a bit then stop charging
The fan slows down and it over heats. Then says check charging system
Jun 20, 2026 at 10:24 AM
  • 55,721 POSTS
Okay, when it says check charging system use the guide to see what the voltage is.
Jun 20, 2026 at 12:05 PM
SMITH29388
  • 5 POSTS
On alternator or battery? The battery is 13.4
Jun 20, 2026 at 12:09 PM
  • 55,721 POSTS
They are there the same when the car is running. Can you please go over the video above?
Jun 20, 2026 at 5:59 PM
SMITH29388
  • 5 POSTS
13.4 is what i got
Jun 20, 2026 at 6:02 PM
  • 55,721 POSTS
That is a little low, it should be about 14.2 did you change out the alternator again?
Jun 20, 2026 at 6:09 PM
SMITH29388
  • 5 POSTS
No just those two times. I can check it again tomorrow
Jun 20, 2026 at 6:15 PM
  • 55,721 POSTS
Okay, sounds good have a good Sunday.
Jun 21, 2026 at 11:12 AM
