Charging system disabled
110,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
DEVON N STEPH CARROLL
All of the threads i have read say that the charging system has been disabled by the PCM.
Aug 5, 2020 at 9:00 AM
STEVE W.
  • 15,410 POSTS
What is the problem you are having?battery not charging or car not starting or??
Aug 5, 2020 at 12:17 PM
Battery not charging.
Aug 6, 2020 at 7:36 AM
STEVE W.
  • 15,410 POSTS
Have you tried anything or had it scanned for codes? Is the check engine light on? There are many reasons it might stop charging. Most will store codes to give you an idea of the problem. Has the car been jump started recently? Is the battery the original one or recently changed?
Aug 6, 2020 at 8:52 AM
  • 55,710 POSTS
Here is a guide to help you get the codes. It sounds like you may need to reset the battery monitors.
Aug 13, 2020 at 9:37 AM
