Charging system?
1991 DODGE DAKOTA
106,547 MILES • 2.5L • 4 CYL • 2WD • MANUAL
BLAMBLAME9
So I just bought the truck it's been sitting for like 10 12 years something like that it's got a hundred six thousand miles on it it's a 4 cylinder 2.5 l with a 5-speed manual two wheel drive people I got it from Lost the key so I had to put an aftermarket ignition in it as easiest way for me to do it got it running ran down the road all of a sudden shut off. check the alternator you need an alternator so I got an alternator put that on still won't charge the battery so voltage regulator external voltage regulator put it in starts right up runs as battery goes down drains out. Where do I go next? any ideas fellas and ladies?
Aug 7, 2025 at 10:25 PM
CARADIODOC
  • 34,367 POSTS
So if I understand correctly, even with a replacement alternator, the system isn't charging the battery, but the engine does run. If I have that right, the system can be broken down into three parts. Start with voltage readings on the large, bolted-on output wire, first with the engine not running, then with it running. Next, measure the voltages on the two smaller terminals on the back of the alternator. Those must be taken with the engine running.
Tell me what you find for those voltages.
Aug 8, 2025 at 6:03 AM
CARADIODOC
  • 34,367 POSTS
Did you get those voltages yet?
Aug 9, 2025 at 11:27 AM
