Charging system
16,000 MILES
RYANCWATERS
I have had the system checked at autozone and they say everything is normal but the Battery has to be charged every couple days and I can not figure out the starter is grinding the flywheel which is putting strain on the battery and maybe that's why it has to be charged
May 11, 2013 at 6:36 AM
yes, the starter motor would do that but it should recover quickly. i think you have a bad alternator. what were the voltage and amp readings they gave you with the print out??
May 11, 2013 at 12:12 PM
RYANCWATERS
I can't find that little piece of paper now, figures huh? I did find the the ground wire from the battery to the car is all burnt up so that may be the whole problem I hope. I'll change that and let you know what happens. Thanks for you're help.
May 12, 2013 at 4:13 AM
