Charging system
202,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JEFF HIEB
Replaced alternator and charged battery. The truck has loss of power will not turn over. clicking noise when i try to start it. worked for a day same problem with last alternator before i changed it. again gauges go out, will not restart unless jump. Started then the battery volts are only eight, but tested battery still twelve volts.
Aug 18, 2017 at 2:21 PM
CJ MEDEVAC
  • 11,000 POSTS
This link is from the top of our page, "repair guides"
My thought is the battery is lacking.
Have it tested fully at an auto parts store (usually a free service).
Need one?
Stroll into their parking lot before you compulsively buy one on the spot! An online purchase can be performed on them new fangled phones.
This might help you out, might try a little homework with it before you go there. See this link.
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
Keep us posted.
The Medic
Aug 19, 2017 at 5:04 AM
JEFF HIEB
Battery has 12.5 volts. what about solenoid?
Aug 19, 2017 at 5:10 AM
CJ MEDEVAC
  • 11,000 POSTS
How are you arriving with the eight volt scenario?
The Medic
Aug 19, 2017 at 5:13 AM
JEFF HIEB
twelve volts battery and alternator are good.
Aug 19, 2017 at 6:45 AM
JEFF HIEB
Maybe solenoid had battery charged just replaced alternator had a loss of power clicks when trying to restart.
Aug 19, 2017 at 6:48 AM
CJ MEDEVAC
  • 11,000 POSTS
At the battery posts.
12.5 ? at a standstill
14 or so with engine running?
If all above is good you will either have a bad solenoid, bad/dirty/loose connections to it or to the starter, or bad connections on any of your big cables. (including grounds).
See my link:
https://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
Your turn,
The Medic
Aug 19, 2017 at 7:07 AM
