Charging system
275,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
THOMAS GUITAR
I have had the charging system tested and once I bring the RPM's up to about 2,000 the voltage output from the alternator drops drastically. On three occasions now when I go to accelerate on the road the car either has shut off or the battery light along with the brake like comes on. Any ideas?
Oct 15, 2019 at 3:17 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Have you had the alternator replaced? It sounds like it might have a bad internal voltage regulator. Hope this helps and thanks for using 2CarPros.
Danny-
Oct 15, 2019 at 6:25 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Danny-
Oct 15, 2019 at 4:40 PM
THOMAS GUITAR
Hi Danny,
Yes, last night I pulled the alternator and took it to both AutoZone and NAPA and both passed it on bench test. So, I replaced the battery and right away as soon as I accelerate the battery light comes on still. Has not shut off yet with the new battery but given the light has come on three times randomly during acceleration I am spinning wondering what it could be. Any advise would be much appreciated.
Oct 16, 2019 at 12:57 AM
DANNY L
  • 5,648 POSTS
Hello again.
Have you inspected the battery cables? Check the connections for looseness/frayed/dirty/corrosion type problems. Have you used a professional type scanner to view live data on the charging system? Hope this helps and thanks again for using 2CarPros.
Danny-
Oct 17, 2019 at 11:07 AM
