Charging system
150,000 MILES • V8 • 4WD • AUTOMATIC
NSTEELMAN
After jumpstarting my truck it only runs a few minutes, all lights go dim and eventually the whole truck shuts off, lights and all.
Nov 2, 2017 at 8:32 AM
  • 31,937 POSTS
Check battery with a load test, you may have to do a bench charge first. also, check the alternator output voltage at the main terminal on the back of the alternator, you should be seeing around 14.5 volts. please post back your findings.
Nov 2, 2017 at 8:34 AM
NSTEELMAN
Alternator reads 12.21 battery has been charging for an hour.
Nov 2, 2017 at 8:45 AM
  • 31,937 POSTS
Alternator out put is to low, get it off and bench tested for internal faults.
Nov 2, 2017 at 9:08 AM
