Charging system
98,000 MILES
WINDSORGUY
I have put a new battery, altornator and voltage regulator when I test the voltage at the battery when the car is running I only have 11.5V. Any ideas?
Apr 28, 2013 at 1:03 PM
CJ MEDEVAC
  • 11,000 POSTS
CLEAN THE CONTACTS ON THE VOLTAGE REGULATOR REAL GOOD (WIRE BRUSH/ SANDPAPER), YOU MIGHT EVEN "TWEAK" THEM A LITTLE SO THAT THEY HAVE A "PRESSURE" AS THEY CONTACT THE OTHER SIDE..........CAN'T GO WRONG USING A LITTLE DIELECTRIC GREASE!
THE MEDIC
Apr 28, 2013 at 2:52 PM
