Spark plug replacement
130 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
SAILORUSN
Want to change spark plugs (do it myself) how difficult would it be?
Thanks. Gary
Mar 19, 2018 at 12:45 PM
Good morning.
Not hard at all. remove the coils, one bolt holding each and then remove the plugs.
1. Remove the ignition coil(s). Refer to ignition coil replacement (See: Ignition coil removal and replacement).
Note: Make sure that any water and/or debris is blown out of the spark plug holes prior to removing the spark plugs.
2. Remove the spark plugs using a 5/8 inch spark plug socket.
Mar 19, 2018 at 10:08 PM
