Charging issues
185,000 MILES • 4.0L • V8 • 2WD • AUTOMATIC
NOAH ROTH
I do not know what happened, but I went to start my car up and it was showing low voltage but fired up. system was not charging though but yet there is no check battery light on, on the dash. I have replaced the battery, checked fuses and tried tracing the ridiculous wiring, but cannot figure out the issue. Car does shut off when I unhook the battery to see if it will stay running.
Oct 28, 2017 at 4:17 PM
CARADIODOC
  • 34,415 POSTS
Please!
Do not disconnect any battery cable with the engine running!
Every year I did a demonstration on the generator test bench for my students to show what can happen when you do that. It was real easy for the voltage to reach over thirty five volts. That will destroy any computer on the vehicle, the generator's internal diodes and built-in voltage regulator, and any light bulbs that are turned on.
The thinking is that if you disconnect either cable and the engine stays running, the generator must be working but a lot of them will stop working due to the voltage regulator responding to the dips in the "ripple" voltage being produced. That will make a perfectly good generator appear to be bad so that test is not valid.
If a mechanic is caught pulling this stunt he will typically get one verbal warning. For the second offense he will be fired. It is that big a deal.
Some generators respond to the high points in the ripple. That momentary higher voltage goes right back to the field winding and creates a stronger magnetic field. That stronger electromagnet creates a higher output voltage which again creates a stronger electromagnet. It is a vicious circle and voltage can keep on rising until something gives out. The main thing that smooths out that ripple so it does not affect the voltage regulator or the generator is the battery.
Three things are needed to generate the output current. They are a magnet, (electromagnet, in this case), a coil of wire, and most importantly, movement between them. That is why the belt needs to make it spin. One thing that can save you from doing damage by removing a battery cable is not raising engine speed. Generators are relatively inefficient at low engine speeds and their output voltage is less likely to rise to dangerous levels, as long as you do not raise engine speed.
One other thing to keep in mind is batteries give off explosive hydrogen gas. Regardless if your generator is working or not there is going to be a big spark when you remove a battery cable with the engine running. Either the generator's current will be recharging the battery, and that can be up to 20 amps, or the battery is going to be supplying the car's electrical systems, and that can easily be over 30 amps. That kind of current is going to create a big spark when a connection is broken or reconnected. Small arc welders run as low as 40 - 60 amps and look at the sparks they create. The reason we do not hear about more battery explosions is because people are careful to not disconnect the cables when there is current flowing through them. It is also why there are huge warning labels on all battery chargers to be sure they are turned off before connecting or disconnecting them from the battery.
Another common generator problem is one defective diode out of the six. You will lose exactly two thirds of the generator's capacity but system voltage will remain normal or it could even be just a little high from the voltage regulator responding to the greatly increased dips in the ripple voltage.
Iti s always a good idea to wear safety glasses when working around car batteries, but if you still insist on removing a cable while the engine is running, a face shield makes more sense, and have plenty of water on hand to wash any acid off the vehicle's paint.
Ford used to have a really nice generator design that allowed testing right on the back of the unit. Only Chrysler alternators are easier to diagnose. Unfortunately the engineers do not really care about ease of service on GM's and many other brands.
The way you tell if the charging system is working is to measure the battery voltage while the engine is running. It must be between 13.75 and 14.75 volts. There still could be a bad diode though. You need a professional load tester to test for that. Ripple will be very high and the most output current you will get will be one third of the generator's design value. That is not enough to meet the demands of the electrical system under all conditions so the battery will have to make up the difference, until it runs down.
If you find charging voltage is low, suspect the generator. Before you replace it, be sure the "battery" warning light turns on when the ignition switch is on and the engine is not running. That light circuit is the turn-on circuit for the generator's internal voltage regulator. If the light does not turn on, there is a break in that wire or the bulb is burned out. The turn-on circuit will still work if the bulb is burned out because there is also a 510 ohm resistor across the bulb for that purpose.
Once the generator starts producing its output current, the voltage regulator puts twelve volts back onto the dash light wire to turn the bulb off. Typically that is the brown wire in the small connector at the rear/side of the generator. Measure the voltage on that wire if the bulb never turns on. With the ignition switch on and engine off, you should find about two volts on that brown wire. With the engine running, you should have over twelve volts on it.
If the warning light turns off with the engine running, and you find between 13.75 and 14.75 volts at the battery, that only means it is okay to do the rest of the tests, and that requires a professional load tester. Of particular interest besides charging voltage, is full-load output current, and "ripple" voltage. There is no way to sugar-coat this. GM had, in my opinion, the world's second best generator design through 1986, but starting with the 1987 models, they have the worst pile ever. It is not practical to try to take it apart in the field. If you could get it apart without damaging the diode block, you cannot test the critical parts, mainly the voltage regulator. You would want to replace everything that might be causing the problem, and that can cost as much as buying a rebuilt unit.
Besides the miserable repair procedure, these generators develop huge voltage spikes that can damage the internal diodes, voltage regulator, and interfere with computer sensor signals. It is the battery that absorbs and dampens those harmful spikes, but they lose their ability to do that as they age. The lead flakes off the plates, and while the battery will still crank the engine okay, its "internal resistance" goes up and makes it much less effective at damping those spikes. It is common to go through four to six replacement generators in the life of a GM vehicle. To reduce that number of repeat failures, always replace the battery at the same time as you replace the generator, unless it is less than about two years old.
When testing shows you can only get one third of the current the generator is rated for, and ripple voltage is high, one of the six diodes has failed. If you cannot get any output current, and battery voltage stays at 12.6 volts or less with the engine running, the voltage regulator has failed. Both conditions can be caused, in part, by an old battery. Related to this, if your "battery" warning light is working properly, and it turns off with the engine running, the regulator did that simply because it saw some output current. If you have a separate "volts" gauge on the dash, and that is reading low, while you may be getting some output current, it is likely too low to keep up with the demands of the electrical system, and the current flow from the battery is drawing its voltage down. You will need the load tester's results to figure out where to go next. Post the numbers here if you need me to interpret them for you.
I should mention too to check that the serpentine belt is not slipping. That can cause a perfectly good generator to not keep up with demand. The warning light will be off, because the system is working, but voltage will be low because the battery is being drawn down. If your generator has an external fan, push on one of the blades with your thumb. If you can spin the fan, (do that with the engine off!), the belt is too loose.
Oct 29, 2017 at 8:24 AM
NOAH ROTH
Man I did not need you to write me a book. You have to do what you have to when you do not have the tools you need for the job.
Oct 29, 2017 at 9:33 AM
CARADIODOC
  • 34,415 POSTS
I understand completely, but the point of my wondrous novel is the test results are not valid. You could have a perfectly-working charging system and the engine will stall, or you could have a defective generator with a failed diode, and the engine will continue running. Mechanics did your test many years ago when they did not understand how these simple systems work. Today you have me to guide you. The best test is to just measure the battery voltage with the engine running. If you find between 13.75 and 14.75 volts, it is working good enough to move on to the professional load tester for the rest of the tests. This voltage will not tell you if there is a bad diode, but it will tell you the generator is doing something of value.
If you do not know how to use a digital voltmeter, I can help with that, and there is a link I can find for you that will take you to an article for the same thing. If you do not have a voltmeter, Harbor Freight Tools has a perfectly fine one for less than ten bucks. It goes on sale quite often for less than five bucks, and they have coupons to get them for free. Do not waste your money on an expensive meter with all kinds of features no one uses. I bought over a dozen meters over the years for TV/VCR repair, and except for my first one I never paid more than thirty bucks. Today I use those Harbor Freight Tools meters almost all the time because if I drop one or drive over it, I will not be crying alligator tears!
Also, for what you are trying to do, just watch the head lights or the interior lights. You will see them get brighter as soon as the engine starts and they will dim when you stop the engine. That again will not tell you if there is a bad diode, but you will have the confidence to drive to the repair shop without worrying about having to walk part way.
Listen to a weak AM radio station too. With a failed diode, that ripple voltage I described will be very high, and that will often be picked up on the AM band as an annoying whine that changes in pitch as engine speed changes. Spark noise is different. That pulse of noise always occurs for the same length of time, regardless of engine speed. You just get more of them at higher speeds, so the noise gets louder. Pitch stays the same.
Oct 29, 2017 at 10:56 AM
