Charging battery with bad alternator
175,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
SELROD656
My alternator went out.It will start using a battery charger but then drains after I disconnect charger.My battery is in the trunk of the car.Can I leave the charger connected while driving to work then disconnect it when I get there?Or will it damage the battery?
Jun 8, 2021 at 3:12 PM
  • 110,248 POSTS
I'm not sure why you would leave it connected. It won't be plugged into power. Also, you don't want to risk one of the connectors shorting. I wouldn't recommend it.
As far as the alternator, it really isn't too hard of a job. Take a look through this link. It explains how in general how it's done.
https://www.2carpros.com/articles/how-to-replace-an-alternator
If you look at the attachments below, they provide the directions specific to your vehicle. This is what I would recommend doing.
I'm not sure what how the battery would benefit from being connected to a charger while driving. It isn't something I am comfortable recommending. I hope you understand.
Let me know if there is anything I can do to help.
Jun 9, 2021 at 2:20 PM
