charge pressure code?
172,000 MILES • V8 • TURBO • 2WD • AUTOMATIC
BHAMDOC1
  • 410 POSTS
There is a minor rough idle and I deleted all code only thing left alone is 120408: charging pressure control switch-off as consequence
Mar 29, 2026 at 6:56 AM
  • 55,554 POSTS
The 120408 code is usually not the root cause, service information says 120408 (“charging pressure control: switch-off / pressure build-up blocked”) So this is most likely a Vanos code, when the engine is cold at idle does it make a slight rattle sound? if so this is the problem these cars are designed to have this problem at this mileage, but you can try replacing the spark plugs ignition coils, and change the oil with a new filter and then clear the codes to see what happens. Does it have any other codes? Also, lets do a smoke test for a vacuum leak, this video can help:
https://www.youtube.com/watch?v=LRKWV4Are5c
or
https://www.youtube.com/watch?v=xN5pcM-5bso
If you can send any freeze-frame/live data you have for idle, I can narrow it down a lot more. Please go over these guides and get back to us.
Mar 30, 2026 at 12:33 PM
