How can a burnt-out indicator lamp for charging affect the charging system?
171,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
FIXMYPROBLEM
Charging system.
May 27, 2023 at 8:29 PM
BRENDON S
  • 653 POSTS
Hello FIXMYPROBLEM,
It shouldn't affect it at all. It's warning you telling you the battery isn't charging correctly.
Could be a bad alternator, bad belt or tensioner, poor connection at the battery terminals, bad battery, as well as a bad voltage regulator built into the alternator. The alternator might test fine but still have a faulty regulator if the issue is intermittent and doesn't occur during testing.
What other symptoms are you experiencing that would lead you to believe it was the burnt-out light causing the issue?
Let me know what you have got going on and let's see if we can get it solved.
Thank you,
Brendon
May 27, 2023 at 8:51 PM
