How can a burnt-out indicator lamp for charging affect the charging system?
FIXMYPROBLEM
  • 2008 FORD RANGER
  • 3.0L
  • V6
  • 171,000 MILES
Charging system.
Sunday, May 28th, 2023 AT 3:29 AM
BRENDON S
  • 653 POSTS
Hello FIXMYPROBLEM,
It shouldn't affect it at all. It's warning you telling you the battery isn't charging correctly.
Could be a bad alternator, bad belt or tensioner, poor connection at the battery terminals, bad battery, as well as a bad voltage regulator built into the alternator. The alternator might test fine but still have a faulty regulator if the issue is intermittent and doesn't occur during testing.
What other symptoms are you experiencing that would lead you to believe it was the burnt-out light causing the issue?
Let me know what you have got going on and let's see if we can get it solved.
Thank you,
Brendon
Sunday, May 28th, 2023 AT 3:51 AM
