Can I keep the battery in the car while I charge it
80,000 MILES • 1.4L • 2WD • AUTOMATIC
GHALIB
Hi, my car battery is dead and I bought a charger new off line. Usually I remove battery take in the house and charge but instead I want to know if I can keep the battery connected to car and put it on charge. Thank you
Apr 21, 2020 at 12:28 AM
Good morning,
Yes, you can. I would remove the cables first and then attach the charger to the battery.
Remove the negative cable first and then the positive. when reinstalling, positive first and negative last. The negative cable is always the first one off and the last one on.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
Apr 21, 2020 at 12:51 AM
GHALIB
Thank you for fast reply. Do the charger cables have to be put on the battery in a particular way?
Apr 21, 2020 at 1:05 AM
Usually there are instructions but if there is not, the red lead will go the positive cable. On top of the battery there should be markings with a big plus sign for positive and the other is the negative.
Apr 21, 2020 at 1:08 AM
GHALIB
Thanks.
Apr 21, 2020 at 1:27 AM
You are welcome.
always glad to help.
Apr 21, 2020 at 1:31 AM
