Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Engine Cooling
Water Pump
Replace/Remove
How to replace the water pump?
1994 TOYOTA CAMRY
336 MILES • 4 CYL • 2WD • AUTOMATIC
HAMBRICKTIFFANY1
MEMBER
1 POST
I need instructions on how to change the water pump on the car listed above.
Jan 7, 2022 at 1:28 AM
SQM
Experienced Mechanic
Always work on the cooling system when the engine is cool and be sure to drain the coolant before getting started.
I have attached the complete water pump replacement procedure below.
https://www.2carpros.com/articles/water-pump-replacement
Images (Click to enlarge)
Jan 7, 2022 at 6:22 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
