Changing transmission fluid
150,000 MILES • 4 CYL • 2WD
DIVIDES
  • 903 POSTS
Cvt, after you get the car to 107f do you turn the car off and add or you leave it running? Read conflicting reports online.
Jun 18, 2021 at 3:51 AM
  • 110,248 POSTS
The engine needs to be running. If you look below, I attached the entire level test procedure specific to this vehicle. I hope it helps.
Jun 18, 2021 at 2:28 PM
