How to drain and fill transmission fluid?
177,000 MILES • 2.0L • TURBO • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
How to drain and fill transmission fluid, change filter and gasket if any on this vehicle. please.
Mar 25, 2025 at 5:14 AM
  • 55,766 POSTS
Yep, there is a filter, but you will need to remove the fluid pan. It looks pretty straight forward.
Here is a guide to help us:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
ZF Lifeguard Fluid 8
Please check the information int he images below.
Mar 27, 2025 at 2:26 AM
BHAMDOC1973
  • 2,007 POSTS
cool, so just drain and fill till it comes out without needing to get it to specific temperature then check again?
Mar 27, 2025 at 4:27 AM
  • 55,766 POSTS
You need to warm the engine up until the cooling fans come on, then the temperature is correct. Fill until the fluid comes out and install the plug.
Mar 28, 2025 at 2:06 AM
BHAMDOC1973
  • 2,007 POSTS
With engine off.
Mar 28, 2025 at 3:11 AM
  • 55,766 POSTS
?? the engine must be running.
Mar 28, 2025 at 3:14 AM
BHAMDOC1973
  • 2,007 POSTS
I am asking if engine should be off or running after it gets to temperature and then fill.
Mar 28, 2025 at 3:26 AM
  • 55,766 POSTS
Running.
Mar 28, 2025 at 5:05 AM
