How to change the transmission fluid?
155,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
The vehicle listed above is a front wheel drive, 2wd, I need to know the procedure for replacing the CVT fluid and the type and capacity of fluid for a drain/fill. Please
Aug 3, 2023 at 6:31 AM
  • 110,248 POSTS
I attached the directions below for draining and refilling the FWD, CVT transmission. Take a look through them and let me know if you have questions.
Also, the last two pics are the fluid specifications and quantities.
Let me know if this helps.
Aug 3, 2023 at 2:54 PM
