Changing transmission fluid, where is the fill plug located?
136,000 MILES • 3.2L • 6 CYL • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
R-design trim. I need to drain and fill the ATF. Can you tell me where the fill plug is? And the type of fluid and capacity recommended for it?
Dec 1, 2023 at 7:31 AM
  • 110,248 POSTS
If you are adding transmission fluid, you need to remove the air filter box to access the fill port.
I attached directions below for checking the level. The procedure includes adding fluid and what to remove.
Take a look through them and let me know if this helps.
joe
Dec 1, 2023 at 2:57 PM
BHAMDOC1973
  • 2,007 POSTS
What fluid type to use?
Dec 5, 2023 at 5:24 AM
  • 110,248 POSTS
No problem whatsoever. If you look at the pic below, it includes the fluid type and capacity.
Let me know if this helps.
See pic below.
Dec 5, 2023 at 10:24 AM
