changing the lower wheel bearing on front axel
2008 ALL OTHER MAKES ALL OTHER MODELS
OTTOMECHANIC
because I do not have the socket to remove the hub, i need to beable to remove the drive assembly from the differential without removing the hub from the front axel. How do I do this?
Apr 11, 2013 at 3:18 PM
HMAC300
  • 48,601 POSTS
you'll have to try to pull the strut assy away far enough to get axle out good luck on that.
Apr 12, 2013 at 5:46 AM
