changing the ignition lock cylinder
190,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
THIMOTHY1976
can i change the ignition lock cylinder and make my car run?
Dec 17, 2019 at 9:04 AM
SCGRANTURISMO
  • 4,897 POSTS
Yes you can, but you will have to have the new key programmed to the Power-train Control Module [PCM] by either a locksmith or the dealership. This is done intentionally to keep thieves from going around and being able to steal vehicles, and is the only two places to have this done. I hope that this helps.
Thanks,
Alex
2CarPros
May 13, 2021 at 3:36 AM
