How to replace steering rack bushings?
161,000 MILES • V8 • 4WD • AUTOMATIC
DIVIDES
  • 903 POSTS
Any instructions on how to do so?
Sep 10, 2021 at 8:53 AM
  • 110,248 POSTS
I'm not sure which bushings you are referring to. Are you referring to the radial shaft bushing/seal?
Take a look at the attached pic and let me know if that is what you are referring to.
See pic below.
Sep 10, 2021 at 2:03 PM
DIVIDES
  • 903 POSTS
No, the bushing that mounts the rack to the frame.
Sep 10, 2021 at 10:58 PM
  • 110,248 POSTS
Okay, you are referring to the retaining plates.
I attached the directions for removal and replacement of the rack and pinion which include removal of the mounts. Take a look through them. You aren't replacing the rack, but the directions include the mounting/retaining plates. Note: This is for the complete removal and replacement of the rack and pinion. You will not need to perform everything.
Let me know if this helps.
Sep 11, 2021 at 1:10 PM
