Changing spark plugs
2014 DODGE
22,117 MILES • 3.6L • V6 • RWD • AUTOMATIC
ADRICK
How do you locate and replace spark plugs on my car?
Oct 13, 2016 at 1:57 AM
AL514
  • 5,692 POSTS
here is a wiring diagram, this will help a bit, As you can see the spark plugs are under each individual ignition coil. This is a direct ignition system (DIS). you will have to unbolt each coil to get to the plugs. it is not as hard as it may seem. Just be easy and do not break anything and you will be fine.
Oct 13, 2016 at 2:09 AM
AL514
  • 5,692 POSTS
if you are unsure about anything just ask us, there is always an awesome Tech on this site to help.
Oct 13, 2016 at 2:13 AM
