There is not enough room to get a hand in between the front frame cross member and engine area where oil filter is located (sensor is located above oil filter on engine block) in order to change the sensor. If you remove the front lower shroud assembly can you gain access by reaching over the front cross member or do you have to remove engine mounts and lift engine ??
Aug 9, 2013 at 7:00 AM
