Changing oil pan gasket
170 MILES • V8 • 2WD • AUTOMATIC
CADDYTOYS85
Do I have to lift engine to change oil pan gasket on my car? It leaks pretty bad near the oil filter and I have been told twice it is the oil pan gasket leaking. any suggestions?
Feb 5, 2018 at 10:05 AM
Good morning.
Is this a front wheel drive or rear wheel drive?
Feb 5, 2018 at 7:41 PM
CADDYTOYS85
Rear wheel drive.
Feb 6, 2018 at 12:24 AM
Yes, the engine has to be lifted as high as it will go. once it is off the mounts, then use blocks of wood between the frame mounts and the engine.
Feb 6, 2018 at 12:29 AM
CADDYTOYS85
Thanks a lot. I appreciate it.
Feb 6, 2018 at 2:16 AM
