Changing drive belt
170,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
AHARTLEY
  • 120 POSTS
In changing the drive belt there is a bolt with a spacer I'll have to remove. Do I need to support the engine in any way when doing this?
Feb 16, 2021 at 9:11 AM
  • 110,251 POSTS
I'm not sure what spacer you are referring to. However, I don't believe a motor mount needs to be removed, so you shouldn't have to support the engine.
If you look at the attached pic, move the tensioner in the directions indicated to release pressure from the belt. Then you can remove it.
Here is a link that explains in general how it's done. You can use it as a guide.
https://www.2carpros.com/articles/replace-serpentine-belt
Take care and God Bless,
Feb 16, 2021 at 11:11 AM
