Changing battery connectors?
2013 NISSAN ALTIMA
160,000 MILES • 4.0L • 4 CYL • 2WD • AUTOMATIC
WHEJEF1958
Do i need to supply the system with voltage so as to not lose charge for the computers to hold their settings while i change battery and new connectors??
Sep 14, 2024 at 8:29 AM
  • 110,244 POSTS
No, that isn't needed. However, you will lose the time and the presets on the radio. Also, when you reconnect the cables, the engine may run a bit rough or even stall a couple of times until the system relearns its settings.
Here is a link you may find helpful:.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Sep 14, 2024 at 2:20 PM
