How to check the transmission fluid and what type ATF?
176,000 MILES • 6 CYL • 2WD • AUTOMATIC
BHAMDOC1
  • 410 POSTS
Some people say check the fluid via dipstick while car running, others say while car is off, which is it?
How much and what type of fluid is needed for a drain and fill?
Feb 9, 2022 at 3:29 AM
  • 110,246 POSTS
When testing the fluid level, the engine needs to be running at operating temperature, and the transmission in park.
If you look below, I provided the fluid type and the drain and fill procedures, which include how to check the level. (Pic 1)
Here is a link as well that you may find helpful:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
It should be around four quarts for a drain and fill. Start with three and add as needed.
Feb 9, 2022 at 9:31 AM
