Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Uplander
Exterior Light
Turn Signal
REPLACE/REMOVE
changing a front turn signal bulb
2008 CHEVROLET UPLANDER
50,000 MILES • 3.9L • 6 CYL • FWD • AUTOMATIC
DICKSAUTO1
MEMBER
1 POST
I can't figure out how to get to front turn signal bulb?
Nov 30, 2015 at 3:31 AM
DANNY L
Experienced Mechanic
Hello, I'm Danny.
You will need to remove the headlamp assembly to gain access to the turn signal bulb. Here is a tutorial showing how to change a bulb:
https://www.2carpros.com/articles/turn-signal-bulb-replacement
I've attached picture steps below on how to remove and replace the headlamp assembly and turn signal bulb. Hope this helps and thanks for using 2CarPros.
Images (Click to enlarge)
Jan 29, 2021 at 6:49 AM
Add image or video
Ask a new question
Engine stalls while driving
Engine overheating
