Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Brakes
Line
Replace/Remove
Changing master cylinder
2003 FORD EXPLORER
170,285 MILES
NICHOLETTE BANNISTER
MEMBER
1 POST
Do I need to bleed my brake line before changing the master cylinder? And is there a video on how to do this job?
May 2, 2017 at 10:32 AM
CJ MEDEVAC
Experienced Mechanic
See if this helps you with what you are going up against!
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
The Medic
May 2, 2017 at 10:46 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
