Changed timing chain then turned it over manually now out of line
145,000 MILES
TAMBO1112
I placed the timing chains on and they were all lined up with the markings. We turned the motor over clockwise to make sure all of the tensioners were working properly and it wasn’t jumping a tooth. After turning it over numerous times trying to line up the time marks again on the camshafts. I was finally able to line them back up as they were when I put them on; however the main bottom chain is not lined up with the markings on the crankshaft or the sprockets. So how did it start out all lined up starting in the nine o’clock position just how the manual shows and now they all won’t line back up together?
Nov 8, 2020 at 11:13 AM
  • 110,248 POSTS
I have to be honest, chances are you can turn it 100 times and they won't align again. Can you tell me what engine size this is so I can verify what I'm saying?
Nov 8, 2020 at 11:25 AM
