I changed the spark plugs and now I a vaccum leak
2004 NISSAN QUEST
140,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
DADDYDURON
I changed the plugs and since I had to remove the intake manifold there is now a vacuum leak somewhere or I do not know. I checked but everything looks to be okay, but I can not figure out the problem. Any ideas?
Feb 26, 2016 at 4:07 PM
HMAC300
  • 48,601 POSTS
I suggest using choke cleaner and spray around intake, you may have pinched a gasket or it should have been replaced when you reinstalled the intake.
Feb 26, 2016 at 10:56 PM
DADDYDURON
Okay, thanks for your quick reply. So I spray choke cleaner until I find the leak also can I use some intake silicone over the metal gasket?
Feb 27, 2016 at 1:15 AM
HMAC300
  • 48,601 POSTS
I would not use silicone as it messes up the O2 sensors. Replace the gaskets if bad.
Feb 27, 2016 at 3:15 AM
DADDYDURON
Okay, thanks again for your response. I will get another gasket. Thank you for your input.
Feb 27, 2016 at 3:19 AM
  • 55,432 POSTS
Here is a guide on how to find a vacuum leak
www.youtube.com/watch?v=xN5pcM-5bso
Let us know how it turns out so it will help others
Mar 7, 2016 at 8:58 AM
