Drive light started flashing then my check engine light came on
1,111 MILES • 2WD • AUTOMATIC
HLM
  • 7 POSTS
My drive light started flashing then my check engine light came on and speed odometer quit working. i checked the code it said speed sensor. i had the shop change it and a new plug in for it but it did not work and the drive light still blinks and check engine light still comes on.
Dec 14, 2018 at 4:14 AM
Good afternoon,
What speed sensor? the one on the transmission or the vehicle speed sensor on the output shaft?
Do you have a copy of the receipt? can you upload a copy?
Was there a code set? if so, what was the code?
Dec 14, 2018 at 4:25 AM
HLM
  • 7 POSTS
i checked the code myself it was one blink and then seven blinks. i looked it up it said speed sensor. what do you mean code set?
Dec 14, 2018 at 5:04 AM
HLM
  • 7 POSTS
it was the one on the the transmission.
Dec 14, 2018 at 5:06 AM
HLM
  • 7 POSTS
the plug in i replaced that to it was all burned and melted.
Dec 14, 2018 at 5:10 AM
Okay, I attached the flow chart for the 17 code. you need to follow the flow chart step by step.
It may be a connection, wiring issue or the ECM.
Dec 14, 2018 at 5:13 AM
