Changed oil and filter
88,207 MILES • 2.5L • 5 CYL • 2WD • AUTOMATIC
CORY2427
  • 293 POSTS
Put everything back together got a little leak where the filter seals at base it’s just on one side it’s not pouring just little seap it came with 2o rings but changed one where it only had one don’t know what it could be
Jan 25, 2019 at 1:23 PM
  • 110,248 POSTS
Hi and thanks for using 2carpros.com
The filter housing has two o rings. One is for the drain at the bottom of the housing and the other goes on the threaded part that attaches to the engine. If you didn't remove the drain, there is no need to replace it. I attached a picture of the drain so you can see what I'm talking about. It is there to drain the housing before you remove it to help eliminate a mess.
Now, if you have a leak at one point, chances are you nicked the o ring when you installed it or you didn't lubricate the o ring with oil prior to installing. That can lead to the o ring binding when you screw the filter housing back on.
I hate to say it, but you need to remove the housing again. Inspect the o ring for any damage. Clean the housing as well as where it attaches. Lubricate the o ring with oil before you install it on the housing and installing it back on to the engine.
Let me know if that takes care of it.
Jan 26, 2019 at 12:13 PM
CORY2427
  • 293 POSTS
Yea I only removed the inside one I did lube o ring and screwed it on tight it’s not leaking all the way around just in back bout finger nail length
Jan 26, 2019 at 1:35 PM
CORY2427
  • 293 POSTS
How much oil will I loose pulling it back off
  • 110,248 POSTS
You will lose very little oil because the canister is in a vertical position.
Let me know. Either the o ring is damaged or there is a problem with the plastic filter lid.
Jan 26, 2019 at 2:29 PM
CORY2427
  • 293 POSTS
Ok figure it out but will it hurt it to drive it until I can get back to it as long as oil is full thing won’t blow off or anything
Jan 26, 2019 at 2:45 PM
  • 110,248 POSTS
If it is tight, it shouldn't come off. I have no idea how much it's leaking, just make sure it stays full.
Jan 26, 2019 at 2:54 PM
CORY2427
  • 293 POSTS
So I got a new gasket replaced it nothing was pinched or tore so don’t know what is going on I cleaned everything real good I managed to turn it little more not leaking as bad but still is housing and stuff is not cracked that I can see but I believe might need tightening more idk I can’t find the right oil filter cap to fit post to be 74mm but slips 73mm won’t fit
Jan 28, 2019 at 10:22 AM
  • 110,248 POSTS
Welcome back:
If it is not tight enough, it can leak. However, the canister can break if over tightened. The actual torque specs for the cap is as follows:
newton meter [N*m]:
25
foot-pound [ft*lbf]:
18.439053733
As far as the tool, are you using a standard oil filter tool designed for this vehicle?
I attached an exploded view of the filter housing. When you install the new o ring, make sure it is all the way up the threaded portion of the cap.
Jan 28, 2019 at 10:34 AM
CORY2427
  • 293 POSTS
So should I try to get a vw oil wrench and give it a turn from tool and see cause can’t get it no tighter by hand
Jan 28, 2019 at 11:30 AM
  • 110,248 POSTS
If you are only tightening it by hand, that is the problem. Once the o ring makes contact, it takes a good bit of pressure to tighten it from that point.
You don't need to get a VW wrench, but you should be able to find one at a parts store. It would be much less money. I listed the torque specs above. That is much tighter than you can do by hand.
I hope this takes care of it. I feel confident it will.
Let me know if you have questions or need anything. Also, let me know if tightening it more takes care of the problem.
Jan 28, 2019 at 12:33 PM
CORY2427
  • 293 POSTS
So 18ft lbs for oil filter canister?
Jan 29, 2019 at 2:23 PM
  • 110,248 POSTS
Welcome back:
That is what the manual indicates. Let me know if you have other questions.
Jan 30, 2019 at 12:22 AM
CORY2427
  • 293 POSTS
So I got a oil filter wrench that fits. tighten it up a little so far no leaks yet. just thought I would update ya.
Jan 31, 2019 at 3:01 PM
CORY2427
  • 293 POSTS
But had one more question. I read the codes and freeze frame data nothing pops up so good on that but service light keeps coming on in the message things. how can I view it? I tried doing what I’ve read no luck.
Jan 31, 2019 at 3:03 PM
  • 110,248 POSTS
Glad the oil leak is fixed. What light is coming on?
Feb 1, 2019 at 4:51 AM
CORY2427
  • 293 POSTS
Service light with wrench. but I cannot figure out how to view it.
Feb 1, 2019 at 12:47 PM
  • 110,248 POSTS
That isn't a problem. It is a reminder to change oil which gets reset when you change the oil. Here is how to reset it:
1) Turn the key to the on position (engine off)
2) Using the control on the steering wheel, select the settings
3) In the submenu, select service
4) Select reset and then OK
5) You may have to press ok again to confirm
______________________
Here is what is listed in the manual:
RESETTING WITHOUT VEHICLE DIAGNOSIS TESTER
Service Interval Display, Resetting Without Vehicle Diagnosis Tester
Using the rocker switch on the windshield wiper lever or the button in the multifunction steering wheel
See picture 1
- Using the rocker switch, select the "settings" menu, or
See picture 2
- Using the button on the multifunction steering wheel, select the "settings" menu.
- Once in the "Service" submenu, select "Reset" and then press the OK button -1- either in the windshield wiper lever or in the multifunction steering wheel -5- to reset the service interval display.
- Press the OK button one more to confirm.
Using the buttons in the instrument cluster.
See picture 3
- With the ignition switched off, hold the -3- button pressed.
- Switch ignition on.
- Release the button -3- and briefly press the button for setting the clock -1- one time.
The Service Interval Display is now in the Reset mode.
After a brief period, the display switches back to the normal display.
Let me know if that helps.
Feb 1, 2019 at 1:24 PM
CORY2427
  • 293 POSTS
Yea, I tried I can’t get in settings. when I get to one thing it flashes that 1330 something. couldn’t reset it still shows thing I do not know.
Feb 1, 2019 at 1:44 PM
CORY2427
  • 293 POSTS
Mine doesn’t have anything on steering wheel or a menu thing.
  • 110,248 POSTS
If it's flashing 1330, that is a diagnostic trouble code for a knock sensor. You should be able to get to menu to reset the oil maintenance light. All of the 2012 models have the reset menu. Yours is on the wiper arm.
Feb 1, 2019 at 1:54 PM
CORY2427
  • 293 POSTS
It’s not a code that mileage it showing. I can’t reset or view anything. I used my code reader to see if it had codes it has none.
Feb 1, 2019 at 2:15 PM
CORY2427
  • 293 POSTS
I know it’s on the arm but can’t get to where I need to to reset anything.
Feb 1, 2019 at 2:17 PM
  • 110,248 POSTS
I thought that was mileage. LOL
If you are still unable to reset the oil reset light, try disconnecting the battery for about ten minutes. See if that allows the system to reset.
After thought. Maybe it is still the older style set up. It may be an early production 2012. See if you have these buttons and if they work:
See Picture 1
Note: You will lose your presets on the radio if you disconnect the battery.
Feb 2, 2019 at 12:11 PM
CORY2427
  • 293 POSTS
What type of refrigeration Freon does 2012 VW Beetle take and how do I do it where is the low port side at? My A/C is not cold.
Feb 4, 2019 at 1:46 PM
RENEE L
  • 1,260 POSTS
Hello CORY2427,
Please post your new question regarding A/C and Freon here.
We need to keep this question and answer thread on the same topic otherwise the site cannot properly index it.
Thank you,
Renee
Feb 5, 2019 at 9:07 AM
