After an engine swap/replacement vehicle ran, but now will not start?
2007 CHEVROLET TRAILBLAZER
175,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
JWITTEN
Put motor from 2005 trailblazer in the 2007. Same size motor. The motor ran for awhile but now will not start. Tried everything. The fuel pump is kicking on. Do not know what it could be. Could it be security.
Sep 19, 2020 at 5:06 PM
Good morning,
Does the theft or security light go out after about 10 seconds with the key on?
https://www.2carpros.com/articles/how-to-reset-a-security-system
Can you check the fuel pressure to see if the pump is producing the correct pressure?
Can you check to see if it has any spark? When you crank the engine, does the tachometer on the dash move up a little showing RPM? That will tell me if the crank sensor is sending a signal to the ECM.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
I would also check the compression to be sure the engine is not damaged internally.
Sep 19, 2020 at 7:20 PM
