changed knock sensor
250 MILES • 2.2L • 4 CYL • 2WD • MANUAL
MARC ROCHON
I changed the knock sensor since the machine gave to me the problem: PCM Knock sensor circuit, but after changed it the car doesn't start again.
What can I do?
What can I check?
Aug 21, 2019 at 11:36 AM
  • 110,248 POSTS
Welcome to 2CarPros.
The first thing I'm going to provide is a link the describes the most common causes for a crank no start condition. Take a look through it first.
Next are the directions for replacing the sensor. Take a look through them and confirm you did what is described. The attached pictures correlate with the directions.
_____________________________________________
2002 Pontiac Sunfire L4-2.2L VIN 4
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Knock Sensor Service and Repair Procedures
REMOVAL PROCEDURE
pic 1
1. Remove the air cleaner outlet resonator.
2. Remove the knock sensor wiring harness connector from the knock sensor.
pic 2
3. Remove the knock sensor from the engine block.
INSTALLATION PROCEDURE
NOTE: Refer to Fastener Notice in Service Precautions.
pic 3
1. After cleaning the threads thoroughly, install the knock sensor into the engine block.
Tighten
Tighten the knock sensor to 19 N.m (14 lb ft).
pic 4
2. Install the knock sensor wiring harness connector to the knock sensor.
3. Install the air cleaner outlet resonator.
If the directions were followed, then I need you to check for ignition spark. Here is a link that explains how that is done:
Here are a few links you may find helpful when testing for spark:
Aug 21, 2019 at 12:39 PM
