I changed IAC. Car still idles up and down. Should I change the PVC and where is it located on my engine?
Dec 22, 2015 at 12:00 AM
WRENCHTECH
✓ASE Certified Mechanic
You need to check real carefully for any vacuum leaks and then I would scrub out the inside of the throttle body and throttle plate.
Dec 22, 2015 at 5:27 AM
KEVINMACK62
MEMBER
Where are those located?
Dec 22, 2015 at 2:49 PM
WRENCHTECH
Where is what located. You have to know where the throttle body and throttle plate is. You just changed the IAC.
Dec 22, 2015 at 3:11 PM
