changed fuel pump, car shut down want start
189,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
BOZIEMCGAHEE
put a new fuel pump on car, start up then after few mint. then want start up, then sometime runs good, then goes through not starting again
Feb 25, 2014 at 4:39 AM
WRENCHTECH
  • 20,758 POSTS
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can ONLY be tested during the failure. Any other time and they will simply test good because the problem isn't present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That's what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the + terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
Feb 25, 2014 at 4:52 AM
BOMBASTIC
Check your fuel filter! After checking mine and changing it that fixed my wife's car. I changed camshaft and crankshaft sensors, including the throttle body with the sensor and still the same results! The fuel filter was the culprit!
Dec 9, 2018 at 9:08 PM
