Changed fuel pump now it will not start
150,000 MILES • 2.2L • 4 CYL
BEANO DAMAGICIAN
Car will drive some days then it will not start. I changed the fuel pump the same day and the car started fine for a day or so now it will not start again. I cannot hear the fuel pump come on again. what could be the problem now? please help!
Mar 7, 2017 at 8:45 PM
AL514
  • 5,700 POSTS
what is the sub-model? (Base, LS, LS Coupe)? and is it automatic or standard transmission?
Mar 7, 2017 at 10:08 PM
AL514
  • 5,700 POSTS
Just wondering off hand, did you replace the fuel filter or any other components during the repair? do you have access to a fuel pressure gauge and what was the condition of the connections on the top of the fuel tank? was the top of the tank very dirty and connector hard to pull apart?
Mar 7, 2017 at 10:12 PM
BEANO DAMAGICIAN
It is a bar model automatic transmission and no the connectors did not have sort around them or hard to pull apart. well the gas pump seal so the pump from pumping. I also checked the relay and it seemed fine. I did not change the fuel filter though.
Mar 8, 2017 at 5:21 AM
BEANO DAMAGICIAN
Base model. did not have dirt around it. will the gas pump seal so it from pumping. whatever the problem is I am not getting fire to the fuel pump to even make it cut on.
what components affect that?
Mar 8, 2017 at 5:24 AM
AL514
  • 5,700 POSTS
assuming you have checked the fuel pump circuits with a test light, you'll have to go to the fuel pump relay next, there should be a fuse box under the hood with relays and fuses. they should be labelled.
Mar 9, 2017 at 11:18 AM
