Changed ecu
163,545 MILES • 3.5L • V6 • 4WD • AUTOMATIC
NEDLOB
  • 24 POSTS
I changed out ECU and rewired B wire harnesses two wire had come out of harness. Now car will not go through all the gears. Will having ECU flashed fix this?
Jun 19, 2017 at 4:23 AM
STEVE W.
  • 15,410 POSTS
Possibly, what was wrong with the old ECU that made you change it out? Is the replacement new, used or a remanufacture unit?
Jun 19, 2017 at 4:36 AM
NEDLOB
  • 24 POSTS
Used from same year and type Sorento.
Jun 19, 2017 at 5:56 AM
NEDLOB
  • 24 POSTS
Two wires had corroded out of harness.
Jun 19, 2017 at 8:11 AM
STEVE W.
  • 15,410 POSTS
If the old one is still working try putting it back in and see if you get the gears back. You may also want to have a transmission shop scan it, there are some codes that don't turn on the light but are still a problem.
If the old ECU is trashed then testing and a re-flash may help but you need to see if the transmission is being commanded through the gears as it shifts or not. It is possible you have a transmission issue as well.
Jun 20, 2017 at 6:50 AM
