Changed battery, check charging system light stays on
2006 FORD FUSION
75,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
KAYMAN
Old battery started car but drained easily when not running, ie; interior light left on for five minutes would then require jump start. Installed new battery and car starts and all functions perform but , "check charging system" light stays on where it did not prior to installing new battery. The negative cable casing, about an one and a half inches, had worn away (I think because of vibration due to its location) I cleaned the exposed corrosion that was visible and used electrical tape to mend. Everything else seemed in good condition. Ran the car for an hour and also turned on A/C, all systems worked fine. Each time I start car that CCS lights.
Aug 16, 2018 at 4:47 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Have you checked the alternator? New batteries can last a while but as long as the alternator is charging the battery back up again. Local auto parts stores will check them for free. I have attached a link explaining how to change one. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/how-to-replace-an-alternator
Aug 16, 2018 at 11:15 AM
