Blows cool air when going at constant high speed 55 to 70 mph
2013 NISSAN ALTIMA
101,789 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
KEVIN STILL
Blows cool air when going at constant high speed 55 to 70 mph. Changed A/C condenser, as per mechanic.
Aug 15, 2019 at 2:39 AM
Hi Kevin,
This could also be a fan issue or a low Freon issue. When you recharged the system did you pull the system into a vacuum? If not then you have moisture in the system and this will cause what you are seeing.
If you did evac and recharge it properly then get your pressures on the high and low side and we can go from there. Here are videos and guides to show you how to recharge your air condition system and find the charge port.
https://youtu.be/uZrQCGwXfek
and
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
and
https://youtu.be/ON2dYcmXIAw
and
and
https://www.2carpros.com/articles/how-a-car-air-conditioner-works
Let us know what happens and please upload pictures or videos of the problem.
May 24, 2021 at 12:21 PM
