Change to a new battery interstate
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
GRENFROGS
Is there anything I need to do different I am putting a new battery in the crossfire. Pos then neg and then start the car any buttons I need to push or does it need to be programmed for this new battery, thank you for your time
Mar 5, 2014 at 2:21 PM
HMAC300
  • 48,601 POSTS
you may have to reset the security system if yo have it due to disconnecting the battery if no manual look onine on how to do it.
Mar 5, 2014 at 9:43 PM
HOMER1967
  • 875 POSTS
the car will probably run rough stall at first,but that is normal.just keep it running for about ten minutes or drive it a few miles if you can and it will re-learn on it's own.as far as the battery is concerned you ALWAYS remove the positive cable first and hook it back up last.
Mar 6, 2014 at 12:02 PM
